Noisy m41
Amazon driver
Hello. I’m dealing with rattling and whining on a D-type M4 in 3rd gear all other gears are good. It shifts fine.
Emptied out oil and found metal filings on plug magnet. It came out of a P1800 probably mid ‘60s, unknown mileage.
What typically is the cause of this? I installed it on my ‘67 122s wagon with the drive shaft shortened and balanced.
3rd gear is in the middle of the case, farthest from the bearings on either end. When you get wear and play in the bearings, it's the one that gets the most gear lash under a load as the main shaft deflects away from the layshaft..
It's hard to say what's wrong without taking it apart and looking, unfortunately. I've had my M41 apart a few times. Once to replace a couple of broken syncro rings (when I first got it, installed it, and found a couple of gears with almost no syncro action), more recently when I was trying to get it to stop leaking oil as much and accidentally pulled the back end out too far, lolgroan.
Here's a great guide on how to take one apart and put it back together. It's not terribly hard, but it's... weird. If you're used to working on engines, the way transmissions are assembled isn't intuitive.
Lots of pics of taking an M40 apart, same as an M41 other than the output shaft: https://www.advrider.com/f/threads/volvo-m40-transmission-rebuild.641530/
Thanks John for the link and info on 3rd gear location in box. Ill be removing m41 out car soon, can’t wait to see what it looks like inside. Will let you know.
Carl
