OD Solenoid Removal: Aisin-Warner's Transmissions
84B23F
Kansas, USA
FWIW, below pic shows tools required. For a AW70L, I had to use the box-end side of the wrench on front bolt, and the crow's foot on rear bolt. I first cleaned all sides of solenoid area before removing it. I have shop-air, so I could blast away with air. Ramps were used on front end of vehicle. Small amounts of tranny oil will leak, so have a catch pan.
Front bolt was a pill, so I used two wrenches...with box end on bolt, and my finger over the box end, I applied extra torque. via second wrench.
I removed one on my daughters 91 240 (the cursed car that lead me down this wormhole). From what I recall, it truly was a pistol to get both those bolts out. The sorry AW71 I recently installed in my 745 has a nice functional solenoid, so I'll probably pull that one before the trans gets junked.
BTW, did you reinstall with SHCS instead of the hex cap screws?
BTW, did you reinstall with SHCS [Socket Head Cap Screw] instead of the hex cap screws?
I did the by-pass mod, and used the same bolts. As explained above, those tools worked just fine; using the crow-foot on the rearward bolt saved my bacon cause a box-end wrench would not work. It took me some 10 minutes to find that 12mm crow-foot.
The owner of the 82 245 that I am in the process of buying, said that he had to replace the selenoid on the AW 70 because "a wire was hanging down". What is the wire connected to and if it was no functioning properly, what effect would it have had on the operation of the transmission.?
Thanks
Thanks
It would have made it so that the button on the shifter couldn't lockout overdrive manually. The transmisssion would work fine otherwise. Or maybe it would have made it so it couldn't go into overdrive, making it basically a 3 speed auto. I'm guessing the latter? Also the wire would be easy to fix without replacing the overdrive solenoid completely, so who knows the full story?
i've never had a Volvo with an AW70. Many, many 240s with 4speed+OD. So, on an '82 there is a button on the shifter that when depressed, locks out OD? He has said that it has a hard time shifting into 4th-overdrive I guess. Said that you have to get it up to about 45 before it will shift into overdrive. Does this all make sense?
Obviously it depends on your rear end gearing but shifting into overdrive around 45 mph seems... normal? if I recall right in my 4.10 740 overdrive is about 2100 rpm at 50 mph. So I can't imagine you'd want to be in overdrive at a speed much lower than that, unless you want to lug the engine.
Thanks
There is a button on the side of the shifter that lets you disable over drive. The wiring goes down the side of the shifter, to a joint under the carpet on the passenger side foot well next to the center console, then exits through the floor into the transmission tunnel.
The coating on this wire by now is rotting away so if it touches anything it will ground out and cause the overdrive to not work. Similar to your m46 overdriver button not working.
Your choices would be to inspect the wire, cut and replace where needed if the coating is bad, and reconnect to the overdrive solenoid. Or, buy a block off plate so you don’t have any stupid electronics controlling overdrive and live a happy life.
Would you explain about the 'block off' plate, please? What do I do and where would I buy the part? Seems like that is the way to go.
Just to explain why this is happening since nobody's been specific yet. For whatever stupid reason the solenoid on the AW70/71 is normally closed. When 12V is applied it opens, allowing fluid to flow and enabling 4th gear / overdrive.
When you hit the lockout button to toggle the overdrive off it triggers a latching relay that just cuts power to that solenoid. Which means that if it loses power for any other reason you lose 4th.
The "blockoff" plate just replaces the solenoid with an open passage that permanently enables overdrive. However you won't be able to disable 4th anymore for towing, hills or engine braking unless you shift all the way down to 2nd.
I like keeping the functionality so IMO it's worth getting under the car and seeing what's left of the solenoid setup. If there's wire still, try jumping 12V to it and see if you can hear it click. If a broken wire is the only problem it's a fairly straightforward fix.
I really wish the solenoid worked in the opposite direction (closed / 4th disabled when power applied) but alas.
The somewhat blurry photo in post #3 of this thread shows the "bypass mod" which is just Dremeling a passage into the underside of the solenoid to bypass the valve component permanently and essentially turn it into the blockoff plate. Works if it's not leaking and you don't tear up the o-ring seal but is of course not reversible.
You really should fix it properly.
Or, block it off, and give yourself the satisfaction that you thought you fixed it, by taking away a choice that you had (turning off overdrive for third gear) that you now no longer have the ability to do.
I'm in the camp of don't use a block off plate. I use the OD lockout button all the time, it's a nice feature when you have only 100hp, and it's absolutely critical you don't use OD when towing. Fixing a car is not any harder than modifying it.
It’s really a failure in engineering, the way it’s designed. You should never design something to fail resulting in a loss of use like this. The design really should be that if the solenoid goes bad, you simply lose the ability to lock out fourth gear rather than the solenoid failing and now you’ve disabled one of the four main gears in
I remember people suggesting taking off the transmission crossmember and lowering the trans. I remember doing this on my back in a dirt lot. I think I was able to get the solenoid off much easier at that point, but I remember when I went to put the trans back up, things had shifted around and the bolts wouldn't line up anymore.
At a shop, I would quickly lower a trans on a screw jack (pole) to gain better access. On your back in your driveway, I would still probably do it with a floor jack and a block of wood under the pan, but be ready for a possible fight on the way back in when your saggy-ass engine mounts shift.
And fix your car right, don't do all that work to put a bypass plate on there. That's ghetto.
I do kinda get why they did it. It's for the edge case where being in 4th could damage the transmission (towing a heavy load) and the solenoid circuit has failed. They want to make sure it fails to a state which is always safe.
But for all typical use situations it's just locking us out for no reason.
The block off plate is the first thing I remove when I encounter one. It's a terrible idea. The circuit is so simple there is no excuse for not fixing any issue keeping it from working as intended.
