This is a pretty easy job but I've been putting it off for a long time. My car is a '92 240 with a service light reset and tachometer. This car uses torx screws, but earlier ones used phillips head instead.
Step 1, remove the cluster. Two knobs left of the cluster pull straight off. Pop the switch plate out with a pocket screw driver. Pop off the blanks or gauge bezels to the right of the cluster. Remove 4 phillips head or torx screws that secure the cluster to the dash.
Pull the cluster forward til it's against the steering wheel. You may need to remove the steering column panel on top, two screws (phillips or torx). On my '92, there's a round plug, a half-round, a red/yellow connected at the lower corner on the passengers side, a red/white tach signal wire plugged to #1 on the tach, a small plastic connector on the speedometer circuit board, and a pink/grey wire with male disconnect plugged in just beneath the tach (or large clock).
Step2, remove the speedometer from the cluster. Remove the seven screws from around the edge of the cluster and remove the four smaller screws on the back of the speedometer.
Step 3, crack open the walnut. Remove the two small screws and carefully lift the circuit board up, being mindful of the small wires that connect it to the speedo.
If a broken gear is the reason your odometer doesn't work, it'll be obvious. Remove and replace the smalll gear. Make sure it spins freely. A dab of sewing machine oil wouldn't hurt. In mine, the broken gear was stuck to the shaft, but it hadn't spun since last October. Once freed, it spun easily, so I assume it's just from sitting in the same position for so long.
Put the grey plastic disc back inside the odometer and carefully seat the circuit board back in place, making sure the black gear on the shaft meshes with your new gear.
Replace the two screws and slide the speedometer back into place on the board. Be sure that these small connectors on the odometer circuit board line up with the cluster circuit board.
If you don't have a service light, then I don't think you'll have these. Definitely were not there on my '87. Drop the board back into the cluster, making sure the trip odometer reset lines up, and replace all 11 screws.
While it was apart, I cleaned the face of the cluster and the black bezel that was filthy. All clean and back together.
I've reinstalled my cluster and test driven the car...odometer works again.
