Well....does overdrive stay working now???
UPDATE.
Due to weather getting better, I took the opportunity to skip lunch and go test the car.
I confirm that with the "trick switch", OD works as it should. No disengaging at every speed, nor moving the gearshift...nothing.
So I'm now sure it depends on that circuit. And due to fact that I grounded after the relay, it should be ok. The problem is somewhere on the wire, as expected.
I examined better the wires that are crawling under the gearbox: while the part over the chassis is ok, as expected the part under the metal is dry and somehow brittle, as expected on your guys' suggestions. The red (4th gear switch) and yellow cables seem as far as I can see intact but there's only a little part I can reach by hand or see.
The "sponge" around the gearshit can be removed from the op, wihout totally break it? Doe it gives me more room to investigate?
And, mainly: Is it possible to pull out the
entire wiring harness to check it and feed it back in, or is it secured to the gearbox housing in some way? Will I be able to reach by hands the connector in that case to let it "slide" towards the interior of the car?
If I pull it it has some room but I didn't insist too much.
I would like to avoid crudely forcing a new cable in to replace the existing one; instead, I want to keep the wiring looking original by routing it through the black sleeve. I searched for a brand new harness but results discontinued.
And a
million-dollar question, given that next week I’ll have the car up on the lift.
Setting aside the fact that checking the wiring is the first step...
I was thinking about the fact that—as you can see in the video—the overdrive disengages when the gear lever gets a sharp nudge. Could excessive transmission movement be the cause, assuming I rule out an electrical issue?
The transmission mount (if there is one) is definitely from 1981, and the engine mounts are at least 20–25 years old. Could excessive play be "tricking" the sensor?
