Test lamp from positive to the 4th gear switch. Go into 4th gear and the lamp should illuminate. Move shifter. Does the lamp go out? = 4th gear switch going open circuit due to shifter movement
SO the "principle difference" on your method VS what I did is to put a lamp
to see if goes out, instead of shortwiring
to see if it does not go out. Am I right?
At this point, I'll check this too even if I'm quite sure result will be the same, due to fact that I'm sure the switch is ok and wiring too, so there is nothing that can disengage it "electrically".
Meanwhile, I bench tested the old switch I removed: it works as it should. The old wiring too didn't show discontinuity.
(the t-shirt with "overdrive" written on it is purely coincidental, even though it may not seem so
Another thing I noticed, days after intense/long driving the defect is immediately evident and present, and
instead leaving the car off for a long period it seems to "cure" the issue even if for some times/some kms, till you use the car intensively again.
This video from some minutes ago shows I wasn't able to replicate the issue, car has been turned off for a week. Moving the gearshift even with a good deal of force didn't shut off the OD, making the same movement.
This led me to another question: low oil can disengage OD as I've read. BUT I checked level: opened the cap and oil flew out. I re-torqued the cap, but there was still oil that was flowing out: I didn't wait the fill bleed to stop flowing honestly thinking more is better than less. An excessive amount of oil could be related? The switch could be "messed" with oil, that with days of inactivity flows down the case? The old switch was covered on oil, as you can see in the video too while pushing it.
