Papa I need a car - 1984 245 DL - son's first car
started stripping out the interior for cleaning, fixing, dynamat
removing the crusty sound deadening
What's the bucket for? I thought you only shit in 7/9's at the junkyard.
Shitting in 240's on your own property is against the rules.
It's for collecting change!
Gasoline works really well for getting the sound deadening off the roof.
I'll give it a try, I cant remember what I used on my 240 years ago
took the front seats apart to see what I can save - none of the foam
just add more bailing wire
starting to add dynamat around the trunk floor area
started to wash interior parts
do this until the water runs clean
Turns out I have a lot of brown carpeting, maybe 4-5 sets. Im about 1/2 way done washing it.
Used my coating racks for drying
been a while since I updated this
found some rust under/behind driver seat
removed more of the stock deadening
driver front
cleaned up the surface rust and painted
overall pic - gf helped to add a bunch of dynamat (need to add pics below)
today, I cut part of the driver seat support to get to the rust below
of course while cutting the rust out I cut one of the brake lines ... I kept telling myself I need to check and then I never did
done for today, I ran out of good sanding disks
I managed to pressure wash the work area and the inside of the door sill
seats are pretty much 90% done. I need to take pictures and will put them all together once the floor is done
sandblasted, welded up and braced
new foam back from VP on both sides
supervisor
cargo floor is on. I decided to just use the original floor for now. I washed it and glued the edges down before adding a few more nails to the trim. I would have been a huge project to take all the trim off for coating. I have a late model floor I might swap in later on
it was all lose
done for now
at some point I took off, cleaned, coated and re lubed the e brake handle, these get so nasty
Do my car next daddy
dont get me in trouble!
Oh what the fuck. Maybe Cali isn’t so bad.
sure
Coming along nicely! Are you just scraping the deadening without solvent or dry ice?
no, in the fall I use a heat gun and in the spring just elbow grease. I used lacquer thinner because cheap and using straight gas as Morgan suggested got me too high
that seat bracing is a great idea!
thanks worked out great on daugher's car
He's been introduced to something worse than drugs.
It's 3am. Do you know where your child is at?
Oh he's on turbobricks giving people shit
The apple doesn't fall far from the tree
TB trolling!!
Im SO PROUD of him!!! @kyle242gt aint got shit on our father/son bond!
:censored: do what :censored: see
even edited by a mod! :love1:
We both know 'daddy' is okay with it
Papa!
blasted the seat support cutout at work
pretty crunchy
painted and sealed stuff up before welding the support back in. Used a seat frame to make sure it will bolt back up
little at a time
added parts I cut out
done for today
insulation time
front 1/2 of the roof
driver side floor (more has been done but I dont have a good picture)
passenger, waiting for body sealant and paint to dry
bought 3m Thinsulate to add it to cracks and crevices - saw that camper conversion people love to use it
place next door to work cuts various insulation/rubber/foam for OEM tractor manufacturers and I got a 3/8 roll of thermal insulation to go under the carpet and various other places for free fifty. I also have a bunch of 1/4 scraps they throw out every Friday :ninja:
found a virgin bolt in the B pillar, looks like Olaf lost it during the door installation and didn't bother to fish it out
got some eye candy for the cluster from @dbarton ... got rid of the COMMIE measurements but maybe I should have added odd numbers
