The pin ground mod does not work at WOT, only part throttle.I've long been interested if you could tune a B230F with just a T cam and make any noticeable improvements.
My current engine is NA and pretty hopped up with a shaved and ported head and a K cam and I haven't found any off the shelf chips that work, the stock tune works great for me.
You can ground some pins on the EZK to add 3° of timing, if you want to fiddle with timing.
That’s pretty impressiveThe pin ground mod does not work at WOT, only part throttle.
Did you try the redblockpowered NA tune, the original one? It was mapped out in our LeMons car on a dyno...that car had a K cam with 10.9:1 compression ratio, some port work, and a slightly modified exhaust system...it made 144whp when we were done. It outhustled the chipset we'd gotten from Sweden by a fair bit.
Bosch LH 2.4 uses a chippable fuel ECU (assuming your '89 is 2.4) but most of the EZK ignition ICUs (apart from a very select few, and 16v "gold" boxes) are not chippable without adding a daughterboard. You kinda need both a fuel and ignition chip otherwise it will run like, as the kids say; "comprehensive and certifiable ass".
And also there's no real reason to chip tune a bone stock B230F in a non-turbo car. There's just nothing to gain.
So the answer is: yes, but why bother?
OP has not been online since first post.
The car has been stanced, straight piped, slid sideways into a phone pole, parted out and crushed.
I think Kyle found this out with the General Leif car. There was a wide swing in timing that didn't do too much to add power.Hmm. Maybe in our case 6 degrees of timing swing really didn't make a difference to power output. I find it unbelievably hard to accept, though.
Either my brain isn't working right now or I never learned this but I'm trying to think of why this would be the case. I thought *all* engines responded to timing changesI think Kyle found this out with the General Leif car. There was a wide swing in timing that didn't do too much to add power.
I've also found this with NA 8v and 16v engines using aftermarket ECUs, even at higher CRs.
There's a point where adding timing doesn't increase torque anymore, and will eventually start to decrease torque. Even without detonation.Either my brain isn't working right now or I never learned this but I'm trying to think of why this would be the case. I thought *all* engines responded to timing changes
