Persisting 2-3-1 and 2-2-1 lambda codes
93M47
My 93 245 has been running the lambda codes 231 and 221 for lean/rich at part load, and I was advised to replace the MAF (Delphi) and check for vacuum leaks, both of which I have done and upon clearing the codes and turning the car back on, the codes returned. The car struggled on power at cold starts but drives normal once it is warmed up. Any advice on what I should look for next to try to get these codes cleared?
2-2-1 and 2-3-1 are for lean at part load / cruise. More specifically, the O2 sensor is seeing excess oxygen in the exhaust and has increased the commanded fueling by ~25% but still sees excess oxygen. This can come from things - low fuel pressure, clogged injectors, dirty MAF, exhaust leaks letting O2 get to the sensor, misfires leaving O2 in the burnt mixture.
Once it's warmed up, does it run well? Good power, smooth idle, no stumbles, accelerates reasonably? Do you hear the fuel pumps running? Do you hear them prime when you first turn the key on but before starting?
Once the car gets past a cold start, it runs fine and no differently than I would've noticed before. I pulled the spark plugs on it as well, and they looked to be relatively clean. Not sure if this helps at all in the diagnosis, but thank you for the advice so far.
