Long time no update.
Things have been busier than normal around here, and it's been a weird year for car things.
In March, I went from 8 mostly-functional vehicles to 2 rather quickly, so once the brake work was done on the 240 it went right back on the road to bring the count up to 3.
The old girl looked great doing doing her thing, and got a lot of positive attention as per usual. Kiddo wanted some shots of her ride alongside the wagon, so I had to oblige.
Once my car situation stabilized a bit, I got the 240 back up on the lift.
New exhaust all mocked up:
As mentioned before, it's a full 2.5" from the downpipe back. All KL Racing bits.
First step, remove old stuff...
New bits installed and mocked up. The fit of this kit is really good out of the box.
Since this is a euro exhaust setup, there's no O2 provision, nor does it come with a cat. It's also a slip fit with clamps provided, and I'm really NOT a fan of slip fit exhausts.
Fortunately, I'd picked up a TIG welder at a deep discount from a good buddy of mine.
So I have the tool to solve these problems
The plan is to weld up the slip fit joints, add v-band clamps, add a section for a cat, and weld on an O2 bung.
So I got everything marked up:
I got everything cut up, then reinstalled and tacked in place:
Then dropped it all out to start finish welding.
I plan on running a cat, but wanted the option to change it, so I made one of the sections swappable for that reason.
The KL exhaust is steel, while the v-band clamps and cat/cat sections are stainless. I used a mixture of 308l and 309l filler depending on what I was melting together, and played around with a few different purge setups.
Between all of that, upgrading cups, and doing a LOT of practice welding, I have a feeling I've doubled or tripled the cost of the exhaust, but at least I kinda know what I'm doing now. Mixed metals, metals of different thicknesses, big gaps in places - all of these things made the whole process extra challenging.
The head pipe section is one of the last sections I've completed, and is some of my better work. Still not great welds, but they'll do. I think
I was hoping to wrap all of this up last night, but of course I ran out of Argon. Again.
I've had some pretty annoying driveline vibration that shows up around 60-65mph, and some on/off throttle clunks and figured they could be related to the driveshaft. So I picked up a replacement carrier bearing and u-joints, and dropped the driveshaft while I had the exhaust out.
I destroyed a couple of 2-jaw pullers trying to remove the carrier bearing, so I picked up a nice 3 jaw. I spent a good half hour moving the bearing half an inch and breaking tools, this guy pulled it off in ~10 seconds. I should have bought this tool a decade or two ago.
The bearing was a little noisy, but not horrible. And the U-joints seem fine - no play that I can detect at least. I'm still going to replace them, since I have the driveshaft out. I wonder if the vibration could be pinion angle (post-lowering/adding adjustable torque arms) and the clunk a worn out rear end, but I'll see how things are once I get the axle back in.
So yeah, I've got a few things to do before the car comes off the lift. It's a bit of a rush to fit all of this stuff in, as I'll be moving to a new place without a garage toward the end of the year.
