142 guy
- May 31, 2014
- Saskatchewan, Canada
I was out tooling around in my 142 today and noticed that the shift lever on my M41 (1971 with original long shifter) was getting quite floppy. A little closer investigation showed that the shift lever was floppy because the outer chrome lever had just about pulled off the short inner stub that comes out of the transmission. I guess the outer lever had been working up so gradually that I hadn't really noticed it.
The outer shift lever has two inner rubber bushings that fit over the stub lever coming out of the transmission. I replaced those 3 or 4 years ago because of a floppy lever and it tightened things right up. So, I pushed the outer lever down on to the stub and everything was nice and tight again. There is a circlip in the bottom of the outer shift lever ; but, it appears that its sole purpose is to keep the lower bushing in place. As far as I can tell there is nothing that is physically retaining the upper outer lever in place on the stub other than the friction of the bushings, or am I missing something? Have other owner's experienced this and come up with a solution other than glue?
