Simi
Upsetti Spaghetti
- Jan 19, 2012
- Orlando, FL
I am currently collecting parts for my next oil change to install an oil cooler to my b230f+t.
I have the oil cooler and mounts right now but not the sender unit that comes off the block.
In the JY there was a 760 which I pulled the cooler off of, but the sending unit was different, it looked like this:
Could I use one of those on my block, or do I have to run the sender unit from a 240 turbo, such as this one?
I also heard somewhere that the oil sender unit for foxbody mustangs works as well, is this true?
http://www.summitracing.com/parts/FLX-3961/
Next thing is what size fittings do I need to run lines to and from the cooler? I was going to use metal braided lines with screw on fittings at each end, I was wondering what size is required to use them, I would rather stay away from the old oil lines and run new ones.
And is there anything else I need to know about installing an oil cooler to my 240? If you guys have any pictures of what you did, it would really help.
