Kjets On a Plane
- Nov 12, 2002
- Californicated Oregone
Soo…
…it’s been a long time since I’ve done this (and kind of can’t believe I did / kind of know better?), but managed snap the bolt extractor off after drilling a lovely centered hole with a guide bushing and plenty of pressure on the bit all the way thru the remaining ~2” of head bolt.
Drilling the extractor looks neigh impossible or really annoying.
There’s no particular hurry.
Sooner would be better, but the car doesn’t need to leave tmw and lower risk and less frustration preferred?
Broken whiteblock head bolts usually jump right out with a quick bop with the punch, overnight soak in oil and a little heat…
…idk if I got a little impatient or what, exactly, but it’s STUCK.
‘98 V70 T5 and it’s the expected (in my limited turbo whiteblock experience…hope it stays that way?) middle back 2 bolts closest to the manifold collector.
Given dissimilar metals and that it’ll probably take a day + to lap all the valves (burned valve is where the journey began, head flat / didn’t overheat otherwise?).
There’s no huge hurry and it’s broken off 2” below the block deck where the threads start, how about just dissolving it after acetone soaking and blowing it with the air gun plenty 1st?
The 2 x 1/2” dia hole below the head should hold the acid solution reasonably well?
Tape the block deck w/some duct tape / similar and replace the acid with fresh with the mity vac or syringe pipet every so often?
Difficult to stir it &/or give it even exposure to the ferrous bolt at the moment?
Masonry bit or some other source of carbide bit might be effective to remove the extractor (if not the bolt itself?) and I probably only have to drill ~3/8” into the broken piece of fluted extractor if it really comes to that to dissolve the ferrous metal from the inside out.
Any of you do this at home w/primitive tools and grocery store spice aisle supplies?
Flask, virgin material and (chaotic?) lab it is not, can I get it clean enough and solution to flow around the ferrous bolt in the alloy block blind water tight hole well enough?
Doesn’t seem prudent to leave pedestaled heat gun blowing on it…I wonder if i have an old block heater or glow plug I can use on some kind of basic thermostatic / temp sensor on/ off circuit to warm the block to ~150F in a 50-60F (insulated but not heated) garage I can install somewhere?
Evaporation and other concerns?
Distilled water or heat pump water heater condensate filtered a bit sans minerals or chlorine?
Idk where I’d obtain a paristaltic pump to better circulate the solution in the blind hole if the quantity of Alum solution in the recessed hole proved insufficient?
