Keep the IPD turbo cam, it’s great. T3 is for when you want that lumpy idle and run a bigger turbo with higher rpm power.
Lash caps are fine if the valvetrain is controlled, you don’t want valve float with lash caps (or really ever!). I usually longer custom valves and dual springs, so no lash caps and no valve float
Replying here to your other post as well.
The larger turbos aren’t that much of a slower turbo to spool up. The AR has a big impact on that, but that also drives top end performance (or the lack of) and smaller AR turbine housings increase EGTs a lot.
A 0.48 AR on a GTX2860 would hit 20psi at ~2500rpm but drop off really hard at higher rpm’s (even with a massively ported wastegate opening). The 0.63 SR housing was the same boost at ~2900-3000 rpm but had 1500+ rpm of pulling on the top end. So overall a longer rev range of torque and power, and increased power as well.
Tossing in a 0.63 AR 3071 Pulsar you end up with nearly identical characteristics as the smaller 2860 with a 0.63 AR, but with cooler charge temps and a lot more power potential.
