The Hacked Saga: A Tale of Way Too Many Projects (140, 240, 940)
fatcatbestcat
Professional Hack
Mississauga, ON (Canada)
November 2022 Edit
Before you start reading, be aware that this thread is currently under maintenance. It turns out the image hosting 'service' I was using caused a number of pictures from the thread to disappear. I'm currently working on restoring them one-at-a-time, and it's going to take some time, as there's now seven pages to this thread. So far, it seems that only pictures from my hard drive can be restored, so there's always going to be a few that I uploaded from my phone that probably will not exist anymore - I'm sure I can figure something out.
Anyways, back to the thread.
October 2019
Right, before we get to the images, some backstory. I was looking for a project car to fill my time, and I'd gotten into the routine of checking my local Kijiji classifieds for unwanted projects. I narrowed it down to these three cars;
1) A 1969 Buick Riviera with a 425 - $800 (it sold like, the day after the ad was posted)
2) A 1976 Mercedes 300D which was mint, just in pieces (sold the day I called the seller up)
3) A 1996 Impala SS (the owner never got back to me)
So then, Kijiji refreshed, and applied filters that I hadn't checked before (usually, I filter out cars under $500 to get rid of those plebs with '59 Impalas listed for $59). The first ad that came up was for this car, a 1967 Volvo 144S. For $200. I rang the seller up and he confirmed the price was accurate. I drove up the next day to see if it was legit, and a month later, it was delivered. In total, for the car, the parts included, the U-Haul trailer fee and gas money cost me $530.
I realize I'll probably spend well over ten times that on it, but hey, it's a neat car.
The car's a '67, but the previous owner swapped in a B20B, M41 O/D transmission and a later-model rear-end.
The grill is held in with nothing but hopes and dreams. This car came with ZERO fasteners or bolts.
The engine. Note that I have a fiberglass FR fender, and a mismatched steel FL. Also, the tires are 165 spares.
Apparently the fiberglass fenders take different bolts than the steel ones. Fun.
While the interior is terrible, the floors are rust-free.
Some of the parts included with the car. I need to find a new rear bench (since this one doesn't exist).
The car came with five of those steelies (with Volvo hubcaps) and five of those 'Corona' rims.
This is definitely the car's worse side. You can see how small my garage is.
The view from the driver's seat. Note the original blue paint. Hopefully I don't get hantavirus or something.
This is the worst of the rust on the car. I have patch panels, and a welder.
I just had to resize like six images. RIP
Something's fishy. The car has a '72 wood grained dash and short shifter but the door handles are '67-'71.
What's the VIN #?
It could be correct. 11930 is in the range for a '67 144.
Was the dash swapped and a late tunnel welded in?
The grill is correct for a '67 but the front panel has been swapped for a later one. Early front panels didn't have the vertical vent slits between the bumper brackets.
Update:
Been a while since I've really done anything to the car, I've instead been doing mostly research and doing parts runs, as well as figuring out exactly what I'm going to need for the car.
My biggest obstacle at the moment is finding bolts and fasteners for the car, since the car came with very few (if any). Every time I try and mount a part to the car, I cry because I need to pay $60 to get two or so bolts shipped direct from Europe. What I SHOULD do is make a list of all the bolts I'm missing, and actually, that's what I will do.
-Bolts for the fenders (the FR is fiberglass and takes different bolts from the steel FL)
-Hood hinge bolts
-bolt to mount the hinge to the hood
-Seat mounting bracket bolts
-probably some more that I haven't found yet
EDIT: I also figured out what's going on with the car (in terms of mismatched parts).
The body shell and doors are from a '67 car (a factory 144S), but sometime around 1981, a previous owner painted it red (it was originally blue), swapped in a B20 and M41 from a '69 car, and replaced most of the interior components with 70's parts. The grille is from a '69 144S, apparently.
In the meantime, I got some really important parts as well as some aspirational items that I'd like to put on the car, but really don't need to.
-Vital: brand new bosch starter
-Vital: brand new fuel pump - no bolts for it :mad:
-NE: MSD 6A Box
-NE: 'D' profile cam
-NE: used B20F cylinder head (I'm probably going to have it shaved down to try and get 10.5:1 compression so I can make that extra 3 horsepower)
-NE: Cloyes aluminum timing gear set (when I change the cam, I might as well)
-NE: Linkage kit for the redline DCOE manifold that came with the car - despite them being the same brand and the salesperson assuring me that it's the right kit, the heim joints are way too big, so I'll probably either get new joints, or drill the manifold's holes bigger.
-NE: vibration mounts for DCOEs
On a side note, I got the airbox off, and found a hole in the air cleaner element. Looking further, I found a squirrel's nest inside the airbox. The carbs seemed to be stuffed with stuff, so that'll be fun.
Do you have a bolt supply house or well-stocked hardware store somewhere in driving distance? I find that's the most cost effective way to get a bunch of hardware quickly for a project. Get a set of thread gages so you can check the nut plates and threaded holes in the car to determine needed thread size & pitch, then estimate lengths and make a list. I don't think you need to be ordering most of your nuts & bolts from Sweden unless there are some really unique / specific ones that are missing.
Vintage Volvos used a lot of Imperial fasteners with a few metric sprinkled in, and then at some point they went full metric. I'm sure Ian can chime in with the year (or year range) that changeover happened, but I think a 1967 car should be mostly Imperial (inch) fasteners. Are those commonly available at your local hardware store in Candanavia? For stuff like fenders, lights, and cosmetic parts a lower grade should be fine. Use Grade 8 for anything safety related, Grade 5 should be fine for most mechanical parts.
Looks like it should be a fun project...
I probably quoted too much there, but my local hardware store seems to have certain bolts, but not in nearly the quantity that I'm going to need them. I'm sure if I go downtown, I'd be able to find what I need though. Also, it does appear that most of these bolts are imperial.
An obstacle that I'm running into is the FR fender (the white fiberglass one) using a different bolt pattern from the FL. I have, like, 2 bolts to start with for the FL at least, but the only thing holding the FR in is hopes and dreams.
Update:
I've been avoiding working on the car since the 11th because it's well below 0 C outside, and there's like a foot of snow on the ground. My PC crashed, so I made myself an excuse to go outside before work. I actually got the chance to function test the carbs a bit. With them mounted on the engine, with all the linkage, the chokes don't open. While the throttle linkage does move, the actual throttle valves are stuck. I took the carbs off, and tried to free them with WD-40 followed by lithium grease and all of my strength. Nothing. Either I'm into a rebuild or replacing them.
Also, my speedometer is in MPH, so that's changing.
The odometer reads 291,000 miles / 404,000 km.
Considering the possibility of buying a non-running 164 as a parts car. Please advise.
(Also for anyone that had read any previous posts about the car, I've dropped any idea of a budget for the car. I'll buy what I need to, but I'm trying to stay reasonable.)
Update:
Pro tip: WD40 is not a good penetrating oil. Get yourself, at the least, some PB blaster, or some Gibb's or Kroil. WD40 is an excellent water displacing aerosol.
I would soak them in a penetrating oil, and if that fails, soak the bottom portion of the carb (with the throttle shaft) in something like ATF mixed 50/50 with acetone.
Worst comes to worse, google "tom bryant SU carbs" and send him an email. His rebuild cost for a pair is extremely reasonable for the quality of work.
Yeah, I figured that WD-40 isn't so good, it's just what I had on hand. I'll probably head to my parts store pretty soon and try and get my hands on some solid rust penetrant.
I looked up tom bryant, and the guy's in Maine. Ground shipping costs alone make me not want to send them out that far. I'll try and find someone local, if I can't get a hold of anyone, I'll start looking at replacement carbs.
Where in Canada are you? You may have a better time just un-seizing them yourself and rebuilding them. They aren't that hard to rebuild yourself (if a curmudgeon like me can do it, anyone can).
Alright, it's been almost a full year since I've posted at all on this forum. It's the summer now, and I can actually get working on the car again (was really hard to work in the winter because, y'know - cold). A lot of what I've been doing recently has largely revolved around troubleshooting and future plans for the car. The #1 thing on my to-do list is getting the engine running, and I'm hoping that everything else will just kinda fall into place. The car, as far as I'm aware, hasn't run since 2009 and hasn't been on the road since 2002.
It took me a good while to gather parts and enough tools to start taking the engine apart after I figured out it was totally seized. I can't get it to turn with a 4-foot breaker bar. I had some trouble getting the head bolts off too, but a torque wrench set to 150 ft-lbs and some brake fluid (as penetrating oil) did the trick.
Anyway, this is what I found when I took the head off. The rust in #1 just looks like it's on the surface, and peeled off with my fingernails, so I don't think there's any significant cylinder wall damage. No bad ring ridge either. The pistons are completely unmarked (no 'std' or '0.30' markings), which might mean this has never been rebuilt - not sure, but a dial-bore gauge will let me know.
A rebuild shouldn't be that big an issue for me at home. I'll have to get a stand and hoist, sure, but I have most of the parts I'm going to need (B20F head and 'D' cam as well as some timing components I was going to install anyway).
On an unrelated note, the SU carbs I was having trouble with in earlier posts turned out to work fine, but I realized that only after I'd cut the choke cables to remove them. I have Weber 45s, so that's probably going to end up on the car instead of the SUs anyway.
Hello Toronto
Hello , fellow turbo bricker !!!!
Im in Chicago but Ive been in Toronto( City) Its a nice city. Ive been to that Island with the ferry and Ive spent the whole day there. I also went to korean town or so.
Nice new project. I have a 92 wagon with a 7mgte, is here.
Good luck and God speed with the car
Take care
DZ:oogle:
Great news today - a combination of 3-stage rust oil and a torque wrench managed to break the engine loose. Now I can turn it over freely, and the water pump appears to turn and work as well. Alternator is still stuck, but that's better than having to rebuild the whole engine.
There was a bit of surface rust in the #1 cylinder, but I was able to polish it out with 0000 steel wool, and there's no real scratchiness or cylinder wall taper as far as I can tell. I also hit the piston tops with the wool, revealing a small 'D' stamped into each one. The same thing is stamped into the top surface of the block. Can anyone tell me what that means?
