At about 400,000 kilometres it’s in not bad shape.
Righto - what is this oil burning smell?
It’s hitting the top of the exhaust manifold cover.
PCV test - passed the glove over oil filler cap test.
Heated the motor up, drove it, got it doing some real work. Put it in Park, left it running, hood open, oil filler cap off, glove over top - yup it’s got healthy vacuum drawing the glove in.
Where is the oil coming from.
Valve cover gasket looks like the source.
Right then; had a look under the top engine cover - the glorious 24 valve statement piece.
It is certainly going to need attention to properly protect the coil packs and wiring.
Then there are the fasteners; a few seem to be stripped. Guess this is why three of 6 bolts were in place; including one who cannot be removed ( the T30 …, what is the term… dent in the top of the bolt where the driver bit goes in to turn it is now a circular dent).
Puddles of oil. Crud.
Creative connector repair. Crud.
The valve cover gasket replacement looks like an interesting operation when there is an OEM tool to this job.
Can I have one of these covers 3D printed that is robust enough for sitting atop a whole lotta heat?
