Wesdunns70t5m
- Oct 4, 2016
- Fort Smith Arkansas
So, today I went to try and adjust my throttle by the book with no success. I fought with mine for a while until I finally tried something, and my car seems very happy about it so far. I figured I would post this up here for anyone's criticism or comments, and possibly to help someone out in the future. The best part about this method, is you don't have to block off the IAC valve
I'll try to keep this bread and easy to follow along
Step 1: remove linkage connecting throttle spool and actual throttle lever
Step 2: with the car warmed up and running, adjust the small set screw with a flat head screwdriver. My car seemed to be happiest around 900 rpms here
Step 3: adjust linkage arm so it will drop onto the ball socket without moving the throttle any
Step 4: loosen TPS screws, turn towards the driver side fully, and then back to the passenger side. I went slightly passed the point in which it clicks. Tighten screws after this point
Step 5: get in car and shift into gear. My rpms dropped to about 600 rpm here. Go for a test drive and make sure all is good
From me playing around with the adjustments, I found that if your throttle is too closed, you will have a very low idle. With it set too far open, I had a surging idle. Like throttle plate would be open and wanting to idle at say 1500rpm, every few seconds I guess the IAC would get mad and the idle would cut out to like 750, and then right back up to 1500 for a few seconds. It was rhythmic and predictable on when it would drop and catch.
After all my adjustments the car seems to be running better. My symptoms before checking all of this was that the car would start, idle, and run fine. My issue was whenever you let off the gas the rpms would drop to like 400 and sometimes stall. If it didn't stall the rpms would go back to normal and it would be fine again. I had no luck at all blocking off my IAC and trying to set everything that way. I will have to put more seat time in my car but so far it seems much better. Hopefully this helps someone in the future
