thatsthat92906
- Jun 26, 2011
Ok so my girlfriends car 1992 volvo 940 turbo was pissing oil Out the turbo so nice by i am i decided to find a new turbo got it all mounted and all set with that but i went through the car for her coolent change oil all new hoses clamps intercooler ect and i got to tranmission
did the gasket fliter and bolted pan back up ... When it came to refilling i got a funnel with a tube stuck it in the tansmission dip stick line and put 7.9 quarts in wayyy to much im guessing because i dont think 7.9 came out and when i was filling it with the new atf , atf started pissing out the back top of tranny ? Almost like it was an overfill valve up there ? Also i disconnected the two what i believe were transmission lines into the radiator bc rad was changed so basically i need to know was was atf pissing out atf out the back top of tranny and now that rad is empty from the two tranny lines that go into t is there anything that needs to be done with that ? Sorry new to fourm and just need some help
Mine starts slipping and shifting weird at a little over a quart low.
