emil_street
- Aug 25, 2023
Can enyone share primary trigger settings for original 60-2 trigger wheel With the original vr sensor. Can’t get it to work, and om all out of ideas.
Best reguards
Best reguards
It’s not reading at all. 1 goes to primary trigger 2 to sensor ground och the shield is grounded on the engine.Is it just triggering at the wrong time, or not reading at all?
How have you wired it? You've confirmed the wiring at the sensor is correct, and you're grounding the shield to the ECU sensor ground?
With ECUmaster they want sensor shields terminated at the ecu side to the sensor ground. I've set up a couple on redblocks and one on a whiteblock this way with stock sensors and it works well.
