Bricktothefuture
- Aug 11, 2015
- Ithaca, NY
Trying to start this car after installing my cleaned up '76 wiring harness - updated it to '79 style injection with the green relay. Non CIS car. I got it to fire up for just a moment the other day but turned the car off after 10 seconds or so as I wanted to double check any potential fuel leaks, etc. Haven't run this since August and was extra paranoid. Two weird things going on -
1 - The starter doesn't sound like it's engaging the flywheel all the time- I hear more of an even whirring sound than the chug-chug of the compression pushing back. What's odd is that the belts are spinning as I can see the fan moving when I try to start the car. Verified fuel and spark, checked the timing belt marks and have spun the distributor a few times to see if ignition timing was the culprit. Which leads me to the second oddity...
2 - When I either move the distributor to the extreme left or right the frequency valve kicks in for a moment. I thought there was maybe a bad ground or a pinched wire somewhere but haven't found the culprit. I can also get the frequency valve to buzz by either disconnecting the ignition module connector or disconnecting/reconnecting the blue wire that supplies 12V to the module.
I've gone over my wiring diagrams a dozen times and checked out @dbarton's site and everything seems to be where it should be. Anyone ever come across this before?
