Bungcheez3r
- Jan 15, 2023
Yeah, that sounds like my best bet. I might try checking out pick and pulls and some other auto dismantlers and just work on other parts of the car until then. Glad I asked, Frankensteining the engine probably would’ve had me in over my head.Since you have patience, be patient until you can find a 1993-95 B230FT. You will have everything you need. It will be much cheaper and reliable from the start. 400 HP is about the limit with one of these using the stock lower end parts. It will have the correct compression ratio for what you are trying to do and will also have the 13mm rods, oil squirters and will already be set up with an oil return for the Turbo that is already on it.
