V8BRICK
- Nov 14, 2002
- Blacksburg, VA
And the slots where the under tray slides in will let water OUT, right?
Yeah there are factory holes in the lower tray which drain the upper tray, which also had holes.
We (mikeP) decided not to cut out that boxed structure when I wanted to install a 6.0 powerstroke intercooler in my car. I got another IC instead.Nah I don't think it added much/if any structural support. I'm not worried about it other than I need to spritz some white paint down in there!
V8240/vwtechnician - how are you handling the overflow reservoir? Using the small fitting on the cap to connect? And that cap will clear the hood? Is the 16.5" dimension from the bottom of the unit to the top of the radiator cap? Also, how are you managing the relatively low pressure set up required by the 240? I swapped from the 10.8 psig (75 kPa) to the later model 21.3 psig cap (150 kPa) thinking it wouldn't matter. Promptly blew the heater hoses off their fittings at the firewall on the dyno. Lowering the system pressure back to design with the 75 kPa cap seemed to solve the problem.
I used a Jegs universal aluminum with a twin 1" core in mine,part #555-52010. Almost a perfect fit
I know it’s been 13 years since this post but I am nearing the end of my 5.0 swap into my 1992 240 and with the Griffin universal radiator, I don’t have enough room to install a fan between the water pump pulley and the radiator. What did you do for a fan?I just have a big universal griffin in mine.
I did not use a shroud...Didn't feel like building one. I bought two smaller puller fans off of Jegs. I put together a frame that mounted to the radiator structure (not the part of the radiator that is all liquidy). Essentially, each fan was on each side of the water pump pully (no pic, unfortunately). And then on the front, I had a big Jegs pusher fan that I put in there after the stock one gave up the ghost.I know it’s been 13 years since this post but I am nearing the end of my 5.0 swap into my 1992 240 and with the Griffin universal radiator, I don’t have enough room to install a fan between the water pump pulley and the radiator. What did you do for a fan?
