Valvetrain for 960 headed T6, wanting to hit 7500rpm reliably.
244tiCanuck
Edmonton
Hey,
I'm in the middle of building the T6 for my swap, using a 960 head and early (204hp) cams.
960 has 7mm valve stems, I seem to recall seeing some people recommending to use T6 valve springs and retainers because they're a beehive spring. Aren't the RNs 6mm valve stems? I threw out my T6 head a looonnng time ago, so I can't check it.
Is there a good aftermarket setup for high-ish revving on the 960 head?
Hey,
I have a B6284t head on my work bench. I can measure the stems tomorrow.
From what I've been looking at in parts catalogues, they should be 7mm until they went to the 2.9 T6.
I've got a few older RN 5 cyls at the shop here that should be the same. Might just use the springs from them.
I have the same block and head setup on my car and I run these crower 2JZ springs:
Here are some numbers
Stock 960​
Crower 68195-24​
Free length [in]​
1.65​
1.66​
OD [in]​
1.031​
1.045​
ID [in]​
0.713​
0.86​
Rate [lbf/in]​
208.8​
251​
They drop right in and I haven't had any issues at all spinning to 7500. The crower catalog lists these as the spring kit of choice for "9000rpm+" on a 2J, take that information for what you will.
That's great info! Thanks.
The 2J springs have more than enough rate to handle the revs. The ID being a lot larger might cause some issues as the springs will be allowed to vibrate and oscillate more than if they were located tighter to the guide and spring retainers.
Stock 960​
Crower 68195-24​
Free length [in]​
1.65​
1.66​
OD [in]​
1.031​
1.045​
ID [in]​
0.713​
0.86​
Rate [lbf/in]​
208.8​
251​
Hey i'm here to get more info, you juste put the spring in the head without changing lower seat and did you keep original retainer or swap to aluminium or titanium?
Looks like those are the springs to use.
I’m sure the stock crank will do 7500 rpm, but if you were to want to go higher than that the crank from the TT6 was supposed to be lighter and knife-edged from the factory.
This is all fuzzy memories from the Poi’s thread.
