Joss
- Feb 28, 2023
- Estonia, Tallinn
Hi,
I have a problem that the engine starts misfiring after it gets warmed up.
When I first run the engine it idles and runs good, I see that my wideband shows about 12.5AFR, whenever it gets warmed up the wideband jumps to 14.7AFR and the car starts to misfire. I noticed that when the misfire happens the AFR jumps from 14.7 to 16.
I have tried
I hope I did not forget anything that I've tried already.
Added the original pump in between the fuel filter and fuel rail/fuel pressure gauge. Fuel pressure is now at 3bar but it still misfires.
I have tried
- Changing rotor and cap
- Tested and changed ECT, Tested the ECT itself when it was new and out of the engine and tested from the ECU pins after it was installed
- New spark plugs
- New spark plug wires
- Coil changed with known good one from my other car
- Power stage changed with known good one from my other car
- ECU changed with known good one from my other car
- Fuel pressure is at 2.1bar (Edited, just measured again)
- Tested for air leaks, could not find any
- Vacuum test was good
- Timing is on point, tested with the light
- Engine idles at about 900RPM
- Idle valve is tested and is brand new from skandix
- I also tested with the 025 MAF and Green Giant injectros, 025 MAF and normal turbo injectors, 016 MAF and green giant injectors - still resulted in misfire after warmed up.
- There does not seem to be excessive pressure in the coolant hoses
- New fuel pressure regulator
- Has Walbro 255 in tank fuel pump, no under body fuel pump. Was bought 3 months ago.
- CPS changed with brand new
