Sıcaklık ölçerin normal çalışma sıcaklığını göstermesinin daha uzun sürdüğünü kastediyorsanız, termostatı kontrol edin. B230 termostatları, yay / pelet tertibatını yerinde tutan halkayı kırma eğilimindedir ve termostatın her zaman açık olmasına neden olur.
I'm at university now. When I drove the vehicle, the weather was very cold, it was minus degrees, there was heavy snowfall and the hot air conditioner was on all the way. It took 15 to 20 minutes until the temperature indicator came to the middle and the increase was gradual. I will have my brother test it tomorrow. Will this cause any problems?Kötü soğutma sistemi radyatörü?, kaç mil üzerinde ?
It isn't going to hurt anything to drive it the way it is in the short run. It does keep the engine from atomizing the fuel the way it should. It will lead to more fuel contamination in the oil. What you describe definitely sounds like a broken thermostat. No matter what the outside temperature is, the thermostat is designed to not open until the engine is at operating temperature. That usually takes 2-3 minutes when driving the car even in very cold weather.I'm at university now. When I drove the vehicle, the weather was very cold, it was minus degrees, there was heavy snowfall and the hot air conditioner was on all the way. It took 15 to 20 minutes until the temperature indicator came to the middle and the increase was gradual. I will have my brother test it tomorrow. Will this cause any problems?
Thank you very much my twin suspects that the indicator is broken but I know that if the indicator is broken it will not move slowly towards the middle. I have two brands such as Meyle and Magnetti Marelli which one should I choose.It isn't going to hurt anything to drive it the way it is in the short run. It does keep the engine from atomizing the fuel the way it should. It will lead to more fuel contamination in the oil. What you describe definitely sounds like a broken thermostat. No matter what the outside temperature is, the thermostat is designed to not open until the engine is at operating temperature. That usually takes 2-3 minutes when driving the car even in very cold weather.
I have never used either brand as far as a thermostat is concerned. I can't recommend either brand for that reason.Thank you very much my twin suspects that the indicator is broken but I know that if the indicator is broken it will not move slowly towards the middle. I have two brands such as Meyle and Magnetti Marelli which one should I choose.
