Volvo Electric Power Steering (C30 S40 V50 V60 S60 V70) on a 240 | + Power Steering Bypass/Delete Idler Pulley | Installation & Review
Portland, OR
Installing a Late Model S40 Electric Power Steering Pump on a Volvo 240​
Sup TB. I'm back to share another DIY I've been using on my 240 for about a year now. The installation for this is ridiculously easy if you've got the room for it. I'll break down what I did for mounting, the wiring, and thoughts + gallery at the end.
I'll try and post a list of cars this pump came on when I find it later but it's very common
Plus a bonus of how I deleted/bypassed the power steering pump in the exhaust location on my 240. This would work the same for if you have a 740/940 as well. Again, another very simple mod that might help some performance oriented owners.
Mounting​
For clarification, what mostly makes this simple for my case is the mounting. I'm running a +T setup. I'm using a 940 water/oil cooler, so I don't have to deal with a OEM style 240 oil cooler or a NA airbox getting in my way. I was able to mount mine directly under my intercooler hose. I imagine the same location could be used if you were NA, had a cooler, or a large 940 intercooler, but you'd have to adjust your measurement to push it further towards the motor instead of hugging the battery.
I don't have any measurements right now but I will get some and edit this post. The mount setup is pretty easy. I obtained the pump with the original bracket off of a S40 and kept all it's rubber mounts intact.
The first two mounts are straight steel strap and come directly off the battery box and line up with the welded nuts on the power steering pump. I used studs in the location on the battery box so I can hang the pump, install the tray, then cap it off with two nuts.
The 3rd mount is simply bent into the shape of a Z. On the lower side of the Z mount, I bolted it to where the rubber isolator goes for the airbox. I found a m6 rivnut fit this hole without any modification. The top end of the lines up with the pump mount. I got the general shape and length down first, left the end long, marked the holes and then trimmed the ends off.
That's pretty much all there is too it, just 3 mounts. I reused the original isolators.
COMING SOON
The Lines​
The lines were also very easy to set up.
The return line is the original Volvo return line from my old pump. I simply routed it over and hose clamped it to the reservoir outlet. You could remove the reservoir hose clamp and re-clock it for better alignment, but it lined up perfect for my setup.
For the feed line, I used an adapter that goes from M16x1.5 to 6AN. I've read somewhere that it needs a special end that seals with an o-ring on the power steering pump side, but I don't think I used an oring on mine. On the rack side, I used an M14 banjo to 6AN. The feed line I used was an 18-inch pre-made 6AN with a 90-degree fitting on one end and a straight fitting on the other.
Wiring & Controller​
The wiring is another dead simple aspect of this swap.
You really only need power, ground, and a trigger signal. The power and ground connector is large, so you'll want to grab one from the junkyard if you can and cut off as much wire as possible. If you don't have the connectors, they're easy to find on eBay. I ran my power through a maxi fuse, but that's just my preference. I've heard of others using a resettable fuse, though the type you use is really up to you, they all do the same thing.
The 3-pin connector is the trigger. Two wires are CANBUS high and low, and the 3rd is ignition. You only really need the ignition wire but do note that without a CANBUS signal the pump will run at 70% power at all times. The quick and easy way to get a ignition source in 240 is off the coil. The downside to this is the pump will run with the engine off. This isn't ideal cause it means you can't leave the ignition on without draining the battery. I drove it like this at 70% power for a couple weeks and it definitely gets the job done but I really suggest a controller if you're daily driving.
In my case, I went with a GPS monitored controller from ServTronic. This make pump adjustments completely automatic, but alternatively you can buy a manual powered one that lets you control pump speed with a dial on the dash. The other improvement I made was moving the ignition source from the coil to fuse 4 instead. Fuse 4 is only powered when the engine is running, so it allows you to have the ignition on without running the pump and killing your battery.
Review of Electric Power Steering​
Honestly, for me, the benefits outweigh the negatives. I love it for my setup, but there are definitely some things that could be seen as downsides. Firstly would be steering feel. It is overall tighter, more direct, and heavier. I personally don't mind it but if you're used to the over-assisted, floaty OE power steering these cars originally came with then you're going to think the steering is too heavy. I personally never liked the stock power steering, I feel it has too much assistance at freeway speeds, to the point where I felt like I was constantly correcting because it was so loose. This pump eliminated all of that.
Another aspect to consider is the wear on your alternator. The stock 80 amp may be okay if you run only electric power steering, but if you have an e-fan or use your HVAC fan on full blast a lot, then I could see this setup really stressing your system. Personally my 100amp Denso struggles to run even my e-fan but I have since upgraded to a stronger alternator (post about that soon) and the power steering pump is the least of my worries when it comes to electrical drain on my system.
Another thing about my setup. I am using BNE Aluminum Strut Mounts. They're mounted at Ben's suggested OEM-style caster with the Luxe steer bearings. Body roll aside, my steering is very direct. I'm also running ATF instead of the suggested CHF-11s. I'm hesitant to run CHF given that my steering rack has a slight leak at the boots and is original, my assumption is that CHF being thinner would make the leaking worse.
I also like to think removing the power steering pump adds less drag on the engine but I acknowledge that probably has a negligible affect on power when you're running a bigger alternator to compensate. I digress though
Here is my parts list:
M16x1.5 to 6AN: https://amzn.to/4aw8qd7
M14 Banjo to 6AN: https://amzn.to/4kWY9KA
6AN 18inch 90 degree to Str: https://amzn.to/4qO72Y4
Wiring Parts:
Connector Kit: https://ebay.us/m/5R5vA4
Crimp Tool for Connectors
Spring loaded: https://amzn.to/4aOGfoE
Hand Crimper: https://amzn.to/4b2znoN
GPS Controller: https://www.servtronic.com/collecti...c30-c70-s40-v50-power-steering-controller-kit
Maxi Fuse Holder: https://amzn.to/4cdy1sB
80 Amp Maxi Fuse: https://amzn.to/4s2rQMv (I've heard these can draw up to 50 amps, so 80 seemed like a good margin of error for anything going wrong)
Gallery​
Fuse Holder​
BUT WAIT! There's more!
Power Steering Pump Delete/Bypass Pulley​
My main purpose for doing this mod was to be able to move my alternator from the lower exhaust location to the upper driver side mount with a 740/940 bracket. I've heard that this location has better belt wrap for alternator tension and gets it away from the heat. So it should theoretically result in better running voltage. I need all the amps I can get with two electric fans plus electric power steering.
Backstory regarding belt wrap​
Installing the alternator on the driver side was a piece of cake as far as wiring and mounting goes. The real issue begins when you wanna spin the water pump. One option was to use a longer belt and wrap it around the water pump, crank and alternator. This does technically work, I didn't really have any rubbing issues but I just know it's not the way things were intended to run, and I believe you do lose some of that precious belt wrap. It's not an issue but I wanted a more factory setup. (see example of belt wrap below)
The Solution: Off the Shelf Idler Pulley​
The fix for me was pretty simple and the parts just fell into my lap and coincidentally fit well. First thing you need is a Volvo 740/940 power steering brackets. This is pretty much a must if you wanna make an idler pulley. I tried to use the 240 alternator mount and maybe you could make it work with a welder, but I don't have one of those and I needed a more bolt on solution. The other piece of the puzzle is a Dayco tension pulley, with part number: 89025
I believe this pulley was meant for some older 80's Ford engine, but it seems to be readily available for industrial use. It only requires one slight modification to work with a volvo. I used one thick 1/4 inch washer and longer bolt into the pulley. This spaced it out just right to where a factory power steering belt lines up right with the crank and water pump. For the lower bolt, I used the factory Volvo power steering mounting bolts. The tensioner is also the factory 740/940 tensioner for the power steering. Since none of this stuff uses bushings, you get a very nice tight fit on the everything. The tension is great and I've put about 8k miles on this setup. I did initially deal with belt slip issues, but after switching to a thicker 11mm belt, I haven't had an issue
Dayco 89025: https://amzn.to/4aw0RmI
or
Gates 38039: https://amzn.to/4s3aHlI
or
Hayden 5950: https://amzn.to/4r8MCcF
Parts NFS:
740/940 Power steering block mount
740/940 Power steering pump tensioner
Gallery of Idler | Belt not tightened in some pics. 11mm belt recommended​
Mounting to Block and Tensioner​
Lots of adjustment room​
Can see spacer washer here​
Belt Alignment​
Excellent stuff and great write up! I've always stared at these pumps on P1s thinking how easy it would be to use on something as long as you could figure out the belt mounting changes. Plus the pumps themselves seem to be reliable units. Out of the bazillion P1 chassis cars I've serviced over the years I've never seen one go bad. They are easy to find, as well. There is always plenty of P1s at the PNPs.
Have you noticed any change in MPG? We added one of these to your 850 race car to free up as much HP as possible. I am happy with the results there, for my 240 DD i was considering it but mostly to see if i could eak out an extra mpg or so average.
We ended up using a very similar location on the 850 as well.
Very clean install!
The only thing I would note is that when pulling any pump you have to get the harness to the pump - there are 2 variants, and the one I typically see on eBay is not the one that it is easy to buy an aftermarket connector for. I researched it a couple years back when I was rebuilding a spare pump for my C30, can't find my notes now. What makes it confusing is that they list the late style (internal reservoir) as Type 1...
Wrong: These are the later Type 1 EDIT - seems nowadays you can get a pigtail for the earlier style. Or terminals/connectors
Type 2 (early) connector kit (stupid money) Type 2 EPS connector kit
Personally, I do try to determine the manufacturer of the terminals/housing (Yazaki, Sumitomo, TE/AMP, etc.,) and crimp my own.
The lower pump bearings do fail, but there are plenty of online directions for cutting the housing & replacing it
index.php
index.php
Back to the pump types - I was incorrect in my connector links - I edited the post
On the left is the one I ordered off eBay from my link - it's a type 1 - the extra pumps I have are Type 2 (in background) - Type 2 connector on the right. The only eBay source wants $47 for the fucking connectors. I have searched before & can't find any sources for the (Amphenol FCI) in the normal outlets (Mouser, etc.,)
you can also just reuse the stock connector and buy new terminals for them
That only works if you have the pigtail off the original - I have a couple of known good spare pumps - to potentially use on the 245 or the V8 conversion - :cry:
I think i have an extra pig tail you can have. let me see. I might have destroyed it when playing with extracting the terminals.
Thanks Ben! It's the black terminal housing version - if you find it, I can always get it from you at Carlisle :-)
Im really heavily considering this to get rid of some of the freeway floatiness, does anyone know how the servtronic gps controller does at highway speeds? Is there still a lot of assistance or is it a more proper manual feeling?
How's your alignment? Sounds like you need more toe-in.
I could probably use one, but I’ve driven a same year one with everything to spec and it still felt kinda over boosted and floaty on the highway. I feel like the electric power steering being variable and turned down on highway speeds would be more connected. But I’m not sure how much the servtronic GPS controller turns it down on the highway or if it would still feel basically the same as stock.
I agree with the first point, the servtronic gps controller works well to correct it? At Highway speeds does it feel closer to a Manual rack? What percentage of Assistance does it feel like it offers?
Floatiness is more a function of alignment and tires than the type of unit that runs your power steering.
A well sorted 240 with good alignment has great steering feel on the highway with the stock pump.
Start weeding through Mouser or Digikey and I am sure you will find the connector readily available. It will be a b!tch to find as there are so many tho.
NM I see you have looked at those sources already
