Not many options available for heater cores. The old, broken unit was brass, and stamped "Harrison". Is that OE or a replacement?
I opted for a full aluminum aftermarket, with cast tanks. I have greater confidence in it than the plastic tank & hose fitting optioned units from other makes.
Installation was opposite of removal, plus some cleaning along the way.
Interior can't really go back together until the carpets dry out. I flushed them with the hose. Good thing it was mostly Zyrex coolant flush & distilled water, and not actual coolant.
There was just a bit of tire contact at the bumper/wheel well lip, a couple seconds with the angle grinder for some subtle, but necessary clearance, on each side.
Another short-change on the oil. This time I'm moving to Mobil1 10w30 synthetic oil, and a Genuine Volvo filter. Flushed the transmission since reassembly, Toyota Dexron III ATF. Genuine Volvo Coolant and some distilled water.
New Bosch O2 Sensor, remanufactured Volvo Air Mass Meter, I think it's ready for a drive.
