Where can I find B6304 NA builds online?
HiSPL
Fanking Champion 1993
College Station, TX
Its been said many times over the years that there are NA B6304’s out there making anywhere from 240 to 300 Hp using mostly mix and match stock parts. The problem is I can’t find any evidence of these builds anywhere
Do YOU know where they are hiding? Post em up!
Paging @Lankku.
There is also a guy on instagram that has a nice looking B6304 in a 740, but I don't recall any dyno numbers...also seems like he's going turbo now.
Paging @Lankku.
Lol. Thats my thread.
Also I don't have instagram. I was hoping to read some build thread on the web somewhere. Even if I have to translate it.....
My build 5 years ago was -99 S80 2.9l block and balanced rotating assembly, lightly ported RWD head with a valve job and it has been milled 1.22mm. Stock 204hp cams, stock intake. Block has been milled 0.2mm to bring the piston a bit higher. Homemade exhaust manifold because I didn't want to use a BMW one :-P 850 flywheel which has been machined lighter, 215mm sintered 4-puck disc, 8V Saab Turbo pressure plate.
With E85
Dyno pulls and accelerations:
