- Jul 16, 2009
- Monterey/Falun
Nothing wrong with stock pushrods, you have one of those t76 turbos that usually come in those type of kits?
Probably, lol. I’m cheap and haven’t had an issue yet even with double springsStock pushrods wil work but if you are spinning it higher and you have a cam+heavier springs it's a good idea to throw in a set of chromoly pushrods. They are less than $100, and will maybe save you in the event of a misshift as well.
Yeah, it originally had a journal bearing 'CXRacing T76', it lasted around 3500 miles and then got slow to spool, and had a little shaft wiggle. Still feeling cheap and lazy and not wanting to rework anything, I 'upgraded' to the same turbo with a dual ball bearing center: https://www.ebay.com/itm/183767519167Nothing wrong with stock pushrods, you have one of those t76 turbos that usually come in those type of kits?
This Listing Is For One Brand New T76 Dual Ball Bearing Turbo, with Q-Trim 0.96 A/R Turbine Housing.
- Dual Ball Bearing T76 0.96 A/R Q Trim Turbo Charger
- Both Compressor and Wheels Are Ball Bearings
- 76mm Big Compressor Wheel
- 0.96 A/R Q Trim Turbine
- 3" V-band Outlet
- 4" Inlet & 2.5" Outlet
- T4 Flange to Manifold
- Aluminum Compressor Housing, Billet Aluminum CNC Machined Back Plate
Nope, dual wastegates with dump tubes.Are you recirculating the wastegate?
It would be hard to control boost on a recirculated wastegate on a 3" exhaust, but with dumps they seem to be fine up to about 1000hp. From the test videos you gain about 50hp going to a 3.5" or 4" exhaust. I'm going to find a way to do a 3.5" ovaled downpipe this winter. the 3" round barely fits, but I should be able to get a 3.5" ovaled into a 4" ovaled under the car.That’s good, I know talking to a friend of mine that does a lot of tuning on turbo Ls stuff the recirculated wastegates on a 3 inch exhaust are a no no from what he tells me.
I thinik I might need to use some spacers to lift them up an inch or so. They're not bad as is, but I think I lost an bit more than an inch in the swap.
Thanks and oof, I'd have to reeeeeeeally love this car. That's more than I paid for it running and driving$2300. Refurbished, new foam and upholstery. From SRRX Seat in Thailand. https://srrxseat.com/
And two of these: https://www.bneshop.com/products/240-recaro-6-bolt-seat-brackets
srrxseat.com
