Anyone got B23FT green books?
TheVolbro
The Collector
San Francisco, California USA
Hey guys, I?ve got a 1984 760 Turbo with the unicorn B23FT motor and I?m looking for any original Volvo ?green book? service manuals that specifically cover B23FT engines as well as anything that would generally cover things on this car such as vacuum and electrical systems, climate control, suspension, etc.
Thanks in advance!
B23FT engines are covered in the B19, B23 engines 740/760 1983-1984 greenbook, TP 30695/1. It's mostly information relating to rebuilding the engine. AFAIK no one has uploaded it to the interwebz yet.
If you can't find a hard copy let me know and I'll scan the one I have.
I don't have very many greenbooks for the 700 series cars so I can't help with the other info you're looking for.
The following is a list of greenbooks related to the B23FT engine that I found on Volvo's literature site.
B19, B23 (DESIGN AND FUNCTION, FAULT TRACING, REPAIR AND MAINTENANCE; GR. 21-22, 25-27)
TP31614/1
Remove Install Cylinder Head, Intake, Exhaust, Turbocharger, Replace Piston Rings in Car, Cooing System
B19, B23 (RCD.; GR. 21)
TP30695/1
Specifications, Disassembly, Measurements, Reassembly, Thread Repairs, Special Tools
B23FT(PRELIM.) (FAULT TRACING, REPAIR AND MAINTENANCE; GR. 21-23, 25-27)
TP30684/1
Specifications, Fault Tracing, Inspection, Idle and Co-Adjust, Turbo Fault Trace, Adjust
EMIS. CONT. SYS. (DESIGN AND FUNCTION; GR. 25)
TP30726/2
PCV, Evaporative Emissions, LAMBDA SOND, Altitude CPR, Diesel Emission Control, Component Diagram
FUEL SYS. EMIS. CONT. (DIESEL) (DESIGN AND FUNCTION, FAULT TRACING, REPAIR AND MAINTENANCE; GR. 23)
TP31514/1
Cleaning Intake, EGR System Adjust, High Altitude Adjust, Setting Injection Pump, Fuel Mixture
IGN. SYS. (DESIGN AND FUNCTION, FAULT TRACING, REPAIR AND MAINTENANCE; GR. 28)
TP31397/1
Specifications, Theory of Operation, Distributor and Electronic Ignition, E2K 102, 115, 117, 116, REX, Circuit Diagrams
TP31614/1
TP30695/1
TP30684/1
TP30726/2
PCV, Evaporative Emissions, LAMBDA SOND, Altitude CPR, Diesel Emission Control, Component Diagram:)
TP31514/1
TP31397/1
Thank you so much! All the info you?ve given has helped me find a couple of the books I?m looking for on eBay and such places. Much appreciated :)
