- Jan 24, 2009
- KC, MO
Sensors in the gear box or the shifter mechanism. It isn't that easy to set up, but you have to have some kind of sensor or microswitch to determine which gear you're in.
Real talk. These are the things I need to know. This will be our first time with a standalone and I kinda don't know what I don't know....
Price wise, the MaxxECU vs MS isn't that far off after you add in the MS costs for external MAP sensor, serial-to-usb converter cable, and tunerstudio licenses. Also make sure you compare prices on the 8' harness (the 3' harness isn't long enough in most installs).
Yes. I find tunerstudio (live tuning) and megalogviewer (log visualization and offline tuning) both useful for microsquirt. $70+$50 = $120 of software. I don't know what MaxxECU comes with.
I've never found tunerstudio to be particularly difficult to navigate (nor really hondata, or AEM, or for the most part holley. hp tuners can be weird). Of all of the ones I semi-regularly use, I dislike AEM the most. ProEFI's software was (and apparently still is) hot garbage as well, but I don't recall it being particularly egregious in terms of layout.
It's fine and easy enough to use, and thank goodness you can search for things easily enough. I just wish there was a way to change the layout (what tabs everything is under) in TS. The default menu locations are to me.
But maybe I'm just a dumb dumb
you can re-write the config file if you want to move things around, that's what drives the whole thing. Of course if you can sort that out, I'd be willing to posit the rest of it is no longer an issue, soo...
My opinion probably isn't fair considering how long I've played with ms stuff, but I'm not sure how it could be any more intuitive than it is? At some point you do need to what you're doing and what you're trying to achieve beyond "running more gooder", but with say Microsquirt, there's just not that much "stuff". You have the basic setup dropdown, then fuel, then spark, then startup/idle, then accel enrich, and finally the advanced (boost control, outputs, that sorta stuff) buttons, it kinda goes in order of how you'd go through the system.
I suppose my question is who is doing it better (in terms of layout, not features.. to a point that's more subjective than layout lol) in yalls opinion? Not going to hurt my feelings, I'll likely be playing with a maxxecu here before long myself, and I've gone back and forth with swapping to a termi-x on the ls swapped car..
The microsquirt only has 2 injector outputs, so I guess half your fuel is going to be injected off-cycle. Seems crazy to me. What are the consequences of that? The maxxecu street look very nice, but what about knock control?
