Hold the A arm by the end with the bushings and slam the ball joint stud onto a steel table, vice anvil or something similarly hard a few times until it pops out. This might be difficult if the stud is really floppy.
Good god, whats the trick for getting these lower ball joints off? They are stamped "Volvo" and might be original. They don't want to leave their home no matter what I do with the loaner ball joint press from Orielly's.
picture you're smashing a 7/900 volvo roof, works for me eveytime
car is coming along nicely. Are you getting those control arms powder coated ?
also I got some better looking speaker covers. I;ll post some pictures
Is there a neighbor you don't really like ? Use the control arms to knock on their door. You know, just to say Hi like a good neighbor would.
woop! nice
these are what you NEED
and shameless plug
Man, I'm about to do all my bushings and ball joints and am not looking forward to it. You have a press to put it all back together?
Also, I plan on welding a few gussets onto my sway bar mounts on the lower control arms. The ones on my 142 are fine, but that 144 I had briefly had cracks all around the stock welds. Just cut out some triangles from 1/8 or 3/16 plate and have them welding on.
dremels are for fling finger nails and model airplanes
you need one of these
Putting the suspension back together was harder than I anticipated. Everything spun when I tried to torque the bolts down. Finally with enough pressure under the control arms and on the tie rods everything was back together.
QUOTE]
You should have it sitting with all of the vehicle weight on it when you torque the a-arms, ball joints, & tie rods. Without a lift, get a set of ramps and set it on them. Then you can torque everything correctly.
Definitely take it in for an alignment, as Jack has stated. The a-arm shims, if there were any, will be different when replacing 40 year old rubber bushings and ball joints. I didn't put any shims back in mine, I'll let the alignment shop do it once I get the engine & transmission back in.
Steve
get an alignment
QUOTE]
Steve
I have asked a couple tire places around Santa Cruz if they'd do an alignment on my car and they both said absolutely not. Another alignment place said they thought they could but I would have to provide a shim set. Did you guys just have any old shop do the alignment?
I don?t have that problem here even les Schwab can do it
It?s crazy I know adjusting more than toe
