SeriousSteve
staring at my desk
- Dec 8, 2002
- South Wales, UK
Outstanding.
so come forth with these dyno plots eh?
Wow, just wow man, the 405hp at 16psi impresses the crap out of me, from an 8v tractor engine...
Head starting to choke things off?
HAHAHAHAHahahahhahahAHAHAHahhahah
You're joking, right?
Yeah- we are talking about a head that is doing like, 200whp NA. Doubt it is a restriction.
I would put money on it being the turbo reaching the upper right side of the compressor map. Hence the question about the turbo.
In this case I think they're 48/40s, and who knows what else... It's just REAL hard to rotate the camshaft on the head when it's not bolted down to an engine... Them lobes are HUGEEEEEEEEEEEEEEEEEEEEEEEE.spec on Pacman heads:
"they are about 3300 dollars for a 8v 531 head with complete custom works and porting. Includes 46/38 valves, custom enem cam shaft, shim under bucket lifters, dual valve springs..."
Seriously. Can. Not. Wait.Awesome work Peter! I feel fortunate to have seen your car in person, next on the list is to see it in action at the track.
Mmmmmmmmmmmmmmmph. Way too sexy. I guess on the dyno it was like WHAMonce it hit the higher boost.How sexy like does that 2.5 rev?
8.2:1. Rpm, well, I wish he would've taken it higher, because from the looks of things it wants to pull to 7500 or maybe even higher, butttttt Peter wants to keep at least one engine together and strong for a good while, so... Same with the boost. Part of the reason for the smaller increase from the last increase in boost is because they richened it back up a bit during that jump to get back down to conservative afr's. Then there's also the completely stock intake manifold with a 59mm(if i remember correctly) MVP "big bore" throttle body.Unreal!
What rpm? (yes I know, the dyno plots will answer)
What CR?
43whp gain from 16-18psi, then only 27whp from 18-22. Head starting to choke things off?
You mean 551hp?I wish my 8v was 405hp
Indeed my good sir.possibly intake manifold and throttle body
My quess is just exhaust pressures rising a tad closer to boost, I'd say it's normal.
