stonie
- Apr 3, 2016
- Switzerland
So, my other Project.
Dont have so much time to explain all ive done on it, if someone is interessted on something, you can ask.
my 95' 945 Turbo is my other fun car im working on it, is a daily driver, a highway hunter and for all other stuff you can use this amazing car, like f*ck in it.
The reason why i open this Thread right now is ; after 3 months of waiting on all my parts, finally the last part im waiting for came TODAY.
It was the Tilton clutch, waiting time on order was 2 week, at the end it was 3 months...
So, no time for Bla bla, only Specs now:
Redblock
2750cc Stroker kit:
-SPM Billet steel crankshaft 94.5 mm
-SPM H-beam connecting rod
-SPM Piston
Kg2t Camshaft:
-Intake 10.5mm (0.413")
-Exhaust 11.9mm (0.469")
-114* Nock angle
-300* Duration
Headwork:
-46mm Intake Valve
-40mm Exhaust Valve
-Valveguides
-Valve Lifters 37mm
-Double Valve Springs
-Port and Polish Both Sides
-Adj. Cam Wheel
-Kinugawa 20T Turbo
-Lighter Crankwheel
-550cc Injectors right now
-3" Amm ...025 from 960
-Bosch blue Coil with Magnecor Cables & NGK BPR8ES
-3" Ferrita Downpipe with 200 Cell, rest JT-Tuning until behind
-optimized OEM Intake and Exhaust Manifold (Intake i wait on Nathans answer)
-Stonis Chips
-All from DO88 i can get for my car
-Pilot Ball Bearing
-Tilton Cerametallic 2 Disc Ultra High Torque Clutch
-5 Speed M90
-Innovate Mtx-L Wideband
-Apexi AVC-R
-Oil & Boost Gauge
-Pu Engine & http://www.retroturbo.com/?product=m90-pu-gearbox-mount
-Lowered 4cm , Kayba Shocks
-All Bushes from suspension PU . Superflex or Retroturbo
-Volvo Gemini with Bridgestone Potenza RE002
Special Thanks To : Roy940 My Obi-Wan, Lars and his Team from ACM , my Girlfiend with her patience !
For all i forgot; Please don't Cry
Pics:
Redblock
2750cc Stroker kit:
-SPM Piston
Kg2t Camshaft:
-114* Nock angle
-300* Duration
Headwork:
-46mm Intake Valve
-40mm Exhaust Valve
-Valveguides
-Valve Lifters 37mm
-Adj. Cam Wheel
-Kinugawa 20T Turbo
-Lighter Crankwheel
-Stonis Chips
-Pilot Ball Bearing
-5 Speed M90
-Apexi AVC-R
-Oil & Boost Gauge
Pics:
