Trevor57
- Jan 10, 2010
- Chicago suburbs
The car is throwing a 113 code "Fuel trim (lambda control)too lean or rich" At idle it goes from normal to about 1500 rpms or so, and then back down. The cycle takes about 3 seconds. When I pulled the spark plugs, all of them were black. I replaced o2 sensor, maf, iac, tps, checked for vacuum leaks and no changes. I bought this car with problems, so I am starting from a position of uncertainty. I checked ect resistance at the ecu, and it was 1500, which seemed correct. I have also adjusted the throttle body linkage, and tps and believe them to be correct. Any ideas on where to go from here are welcome.
