DMFWallace
Ignoramus Bigotus
- May 1, 2004
- Fredericksburg, VA
I'm about to replace the suspension on my 850 and I'm torn on whether or not to order iPd springs. I'm absolutely terrified they're going to make my car too much lower than it already is. The rear springs absolutely need replacing and the fronts are fairly mushy so it's either iPd or "pro-parts" (scam-tech?) all the way around.
I already scoop gravel into the plastic belly pan when I back into my driveway too fast and I scrape going in to some driveways if there's a dip right before the entry. It's definitely low enough already for a "safe family car".
I'm running S60T5 wheels (205/55/16 factory) which are 0.7" taller than the stock 195/60/15's and I get moderate rubbing on nearly full lock. I intend to do something about the steering stops in the near future.
Based on the very few and poorly angled installed photos on iPd's website, it looks like my ride height won't change a bit, honestly. I would really like to see if any of you all have photos of your wrong wheel drive cars to share if you have unmodified iPd springs (and maybe even 205/55's!)
