Lancer1500
- Jun 11, 2023
How would you guys begin programming the ecu, are there some guids in tuning with ostrich etc..
Bit of a bold statement. Not everyone has the capability, experience or endeavour to make their own chips and just want something that works.Most chips on the market are rubbish (stoni, kl racing, redblockpowered), so I always encourage people to make their own chips because then you know exactly what's happening.
Sure, let me spend all the time and money I don't have on something that could easily go wrong via user error and end up costing even more! Yeah, no. You're like all the guys on LS1TECH telling people to tune their own setup. It's not for everyone.Lancer, you use a chip programmer and its software (I use a TL866II+, here's the new version) to read/write the chips and save the bin file, then open it in TunerPro. After making adjustments, you save the file, boot up the programmer's software again, put a blank chip in the socket, select the file, and burn it.
For chips, a pack of 14 OTP 27c256 28 pin DIP chips from Farnell UK are readily available and quite cheap (~£4 each). The original chips are TI SMJ27c256-20JT 200ns EPROMs with a quartz window under the sticker, they can be erased with a UV light and reused. Other alternatives are AMD AM27C256, ST M27C256B, or TI TMS27C256, and maybe Winbond W27E257.
This thread with my 'chip tuning for dummies' guide contains links to the software, the xdf files needed to use the software, and the fuel/ezk bin files if you wanted to use them for some reason:
Can anyone shed light on ezk/LH2.4 Chips - Volvo Owners Club Forum
Can anyone shed light on ezk/LH2.4 Chips 700/900 Series Generalwww.volvoforums.org.uk
yeah the ostrich I think is NLA. People have had success with Cobra RTP but those are also hard to get now with the whole Russia invasion thing. I am not sure of others.Can it be that the ostrich is out of date, I can't find a place where I can buy one???
Is there something new
I may be wrong, but I believe the female ECU connection is still available from mouser/digikey. That's about as good as it's gonna get.~5 years ago, the SST27SF256-70 chips I got off of ebay worked fine with a MiniPro TL866 programmer: https://turbobricks.com/index.php?threads/eeprom-burner.340001/page-2
The picture in the ebay link you posted is not the right chip, but the listed part number is OK.
AFAIK, there are no LH2.4/EZ116K PnP adapters or wiring harnesses available for aftermarket ECUs. (linuxman51 used to make these for MicroSquirt years ago, but not currently.)
