Gang, I have a curious problem that's appeared.
Tuning the 16v+t at about 75% ethanol in the tank.
This is a flex fuel setup where I blend VE1-VE3. I tuned the VE1 on pump gas and multiplied the entire map by about 50% to get it right until the blended afr matched what I was seeing on pump gas. Needless to say, I never saw the lean spike on pump gas.
This thing is spiking hard lean when I slam on the throttle. pumping up the VE in those spots on the MAP does not make any changes. THe lean spike is dependent on what RPM I floor it. It reminds me of my lh2.4 days. I've already tried playing with acceleration enrichments but that had no effect.
I noticed the spike in the logs when I started tuning with e85. Now that I'm at 75% the spikes are more pronounced. I've never been this high before... normally I only ever get to 55% (I live 45 min from the closest e85 station).
I tried a bunch of things.... decreasing gap to 0.022 (a 0.55mm guitar pick) thinking it was spark blowout or a lean misfire, nothing doing. I could perhaps go smaller on the gap. (dsm coils)
Posting a datalog and a snapshot below.
I'm not logging fuel pressure... I don't even know what the fp is... assuming it's all kosher but I am going to pick up a transducer and start logging.
Your thoughts?
bad regulator? dying pump? Spark blowout?
Your thoughts?
