Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
Believe it or not, the red block 8V valve husher! Same exact part # as what sits under the SOHC bucket & on to of the valve stem retainers.
One side of the TB gets this (I think it is the throttle lever side)..... other side where your TPS mount gets an O-ring. Both sides, the void is filled with silicone grease, which you can buy inexpensively on eBay. You have to seal these cavities to prevent vacuum/boost leaks.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
