DaButcher
Do a Burnout!
- Jan 28, 2003
- Bergen, Norway
B230f+t - CLT from 240?
Hi,
When doing the B230F+T, can one use the CLT from the B230F?
Then there is also the info:
http://www.nuceng.ca/workspace/Volvo FAQ Site/EngineSensors.html#DiagnosingECTFailures
I have to try to diagnose why there is black smoke in the exhaust (and heavy smell of fuel).
It's running all 940t parts.. 940T ecu (chipped) and 240 N/A EZK chipped (563 ECU and 146 EZK).
The lambda might be bad.. but are the ECT values the same for the 89' 240 w/ b230f, as the ~~90 b230ft? I read on that site that there is three sensors in t he b230f, is this compatible with the 940t ECU?
[/FONT]
Hi,
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]
Engine Temperature Sensors. The B230F of the vintage discussed, 1989-1995 have in effect three temp sensors: the Engine Coolant Temperature sensor (ECT)- which has two sensors in one housing - and the temperature gauge sensor. Two NTC thermistors are combined in one ECT sensor housing with two connectors and ground through the housing into the manifold. One of the temp sensor "signals" goes to the LH fuel injection computer, the other to the EZK ignition computer. The third temp sensor is the one used by the temp gauge in the instrument cluster. It also has two connectors, one "signal", one "ground". For resistance ratings, see the link noted. The gauge sensor is at the front under intake manifold runner number two, just ahead of the knock sensor which is bolted in at an angle. Behind the knock sensor under manifold runner three is the ECT.[/FONT] [FONT=Arial, Helvetica, sans-serif]When you remove any of the sensors, disconnect the battery negative cable.
[/FONT]
[/FONT]
