bobxyz
- Aug 29, 2014
- Boulder CO
What's the proper procedure for measuring piston protrusion for a tight squish motor, both for determining desired deck machining and for post-machining head gasket selection?
More specifically, what if there's some piston-to-piston height variation and the pistons all rock a bit? Do I measure protrusion on the tallest point on the piston face at max rock and take the result from the tallest piston, or do I do some sort of average? How much of this, if any, is built into the desired squish numbers?
For discussion, say I have:
5 thou of piston-to-piston variation (rod length or piston pin to face variation or deck tilt)
10 thou of min-to-max rocking (does it matter which direction?)
35 thou desired "tight squish"
nothing special 7500rpm 15psi B21FT
Thanks,
Bob
Thanks,
Bob
