@Stiggy Pop you probably will want to see this.
I got my new Erland special head on and finally got around to tuning it a bit today. It's good, but I still have more work to do. There are a few spots I'm having issues with still.
Here's a dyno plot of the two heads making the same power. The red line is the Erland head with 46/38mm valves and a big cam and the blue line is the old head with 48/40mm valves and an RSI stage 3 cam:
The new head makes the same power at 6 psi less boost, and has the torque come in almost 1000 RPM sooner.
Here's a dyno plot of the two heads at the same boost. Again, the red line is the Erland head and the blue line is the old head:
The torque difference at 4900 RPM is pretty impressive. Those 100 extra ft-lbs are going to feel nice.
This new head really isn't too happy right off idle due to the hog cam, but once it gets some RPM it really picks it up and my turbo spools noticeably quicker.
I would have taken the car further and made 600+ whp, but I've started running into fuel pressure issues, which is why I didn't take it to the rev limiter in the dyno plot. I think I need to finally get an aftermarket fuel filter, and maybe upgrade the stock hard lines to -6 AN. I don't really want to upgrade the fuel lines, but I don't mind getting a higher flow filter. I do want to get to 650ish whp though so something will have to be done to fix my fuel pressure drop.
I meant to take some dyno videos but got caught up in the fuel pressure issue and didn't end up taking any.
I'm also planning on making some kind of custom fuel pump hanger since I need a more reliable fuel level sensor. Mine left me stranded the other day. Luckily I was within walking distance of my house. I'm also debating whether or not I should get some kind of surge tank (which I don't want to do) to get more fuel pump in the system.
