- Sep 18, 2002
So you mean tap the hubs and use BMW type lug-studs, or a thread-in lug like we'd install into the tapped holes on the BMW's?? Seems pointless, just get press-in studs, WAY cheaper, and no worry of not getting the threads perfect (if doing this at home).
They are essentially bolts, they thread in from the back.
And there is a point to doing it that way. The point is that 114.3 is a larger PCD than 108. So you can drill a smaller hole in order to keep the same amount of meat around the bolt hole. If you drill holes big enough for a large knurl, the amount of material around the outer edge of the hole gets thin.
Threaded bolts are not more expensive, in fact i think they might be cheaper (I used moroso), and the issue of accuracy is irrelevant.
If you're seriously so clumsy that threading the holes is a deal breaker, don't bother doing it.
This picture explains the issue. You could use a small knurl I guess but might as well just thread it.
