So just drove my fresh T5 swap for the first time last night. I did not experience any dash rattling or vibrations that made me question the swap at all. It was great to drive with the exception of my needing to figure out my shifter bezel. I did get a slight vibration in the shift knob around 2,700 rpm on deacceleration. This seemed to be nothing like what everyone has reported that drives them crazy.
I tried to use as much rubber as possible
- STS lighted flywheel
- Yoshifab Stage 2 clutch/pp
- Yoshifab rubber t5 mount
- Yoshifab 2 Piece front driveshaft
- Yoshifab T5 crossmember
- May change this out for the STS one as my T5 output shaft doesn't line up 100% straight on with the center carrier
- Driveline angles were pretty spot on with this, -1 degree on trans and +1 degree on carrier
- Volvo rubber center carrier bushing
- 3 sheets of 1/4 50 durometer rubber sandwiched in between the crossmember and frame rails
- Stock rubber rear suspension
- Refreshed T5z with deeworks adapter kit
The t5 swap definitely added some NVH, but I think a lot of it is coming from the fact the I'm trying to shift higher than the auto the T5 replaced.
I may play around with cross member and angles, but so far very happy with the swap.
