the_hairy_baboon
- Dec 1, 2021
Some prior owner of my 1983 245 smeared the front left fender / door. As a result, the wheel well liner got bent, and due to the larger wheels they were running has a worn hole in it. (Also the sweet beltline trim fell off because that portion also got dented). I snagged an undamaged one at a junkyard but realized that because I haven't gotten the fender back to proper shape I can't fit the liner and get all the bolts to line up. So the question is: What is the easy way for a shadetree mechanic to get the fender back to shape - enough that a new wheel well liner will fit and the belt trim can be put on? I don't have a garage to work in, but have decent outside weather.
I tried just popping the dent out with some pieces of wood between the engine bay and fender when I had the liner off and I can get some movement but not really enough to pop out the dent - I think it may be more than elastic deformation. I haven't attempted anything on the door, but I assume taking off the card and removing window components should let me get enough access to gently hammer stuff out.
Pictures of current status below. I included a comparison shot of the right fender.
