Hey
I have a slightly modded volvo 940 which i have been working on for a little over a year and finaly got it on the road, however over the time that i worked on it an issue with the idle came up, it bounces around 650-850 rpm and it stutters when doing so, and it also misfires quite often in idle.
When driving it doesnt like low rpm at all, it jerks and misfires quite alot but it seems to be only when im going below 70-ish km/h and its only when coasting, if i floor it all the issues go away
Sometimes when pressing down the clutch after driving it will dip quite low in rpm and sometimes stall but it seems to be at random meaning other times the rpm wont dip at all.
Here the other day it had trouble starting i had to press down on the gas to start it, but its always a little slow to fire up
I bought the car modded and here is what was done to the car when i got it:
-A holset hx35 was fitted
-AMM was relocated to just before the TB
-unkown injectors
-another camshaft and they adjusted the timing a little bit
-EGR delete
i made some changes to the car myself and i worry that i have messed something up because if my memory is correct then the issue came somewhere along the mods i have done
-Bosch 968 injectors and ignition/fuel chips to match
-walboro fuel pump
-multigauge with rpm gauge, for the rpm gauge i get the signal from the ignition control module(some of my suspicions are on that)
-adjustable fuel regulator
Im forgetting some stuff, but its been bugging me for some time now and i cant tell anymore if the cause is just the camshaft being adjusted.
Anyway let me know what you think
-unkown injectors
-EGR delete
-walboro fuel pump
