yeah no. grp a wasnt na, also 180 isnt easy from k jet. i stuck thousands into a na engine for a while. it takes money talk with krl on here. i ran 11:1 compression with webber dceo's and flattops i bet i maybe made 140 whp MAYBE.
First understand that Group A was a GROUP of classes introduced at the same time as GpB and GroupN
GpA and GpN were a groups of classes for 4 place cars.
Both required minimum runs of 5000 identical cars ie an OEM had to make 5000 of the base GpN car aqnd that qualified them for GpA as well.
All three Groups had classes for 1300cc, 1600cc, 2000cc, 2500cc, and 3,0 and over.
EVERYBODY homologated their cars (submitted Identification papers where EVERY dimension, length, tooth count, weight, etc was identified and photographed.
So there were normal aspirated GpA 1600 cars---my own Saab 96 was rebuilt to GpA spec in late 1986 so i could enter Olympus World Championship Rally in December 1986. This involved making a NEAR STOCK 1,5 V4 (only compression ratio and camshaft were free to mod) and yanking out my big valve +3mm overbored 1700 V4 which was 1815cc------there were GpN 1300s and the GpB cars were mostly around 1700cc cause turbo cars had a 1,7 multiplier for engine voluume.
So of course there were GpA 2,1 normal aspirated Volvo 240s
somewhere, but as it isn't the most optimal motor in stock form and it is a relatively heavy car, it never was popular except in classes that allowed engine mods and there is was at home.
Bur re: your car
What valve sizes did you use?
What camshaft did you use?
You should point out you had smallish---for a motor 2,3 liters---45 DCOEs which are more appropriate on motors for all round use around 1600-1800cc.
And seriously, how did you calculate your compression?
Cause you know that 2300s even with 45s can do outputs around 200-210 with the right bits.
